file management
  • Thread starter Thread starter amchi_in
  • Start date Start date
A
amchi_in
Guest
how do i get back my pro/e file which has been deleted using delete all versions, using a trial file
trail.txt.976 rename to something oops.txt or whatever name you need it to be
but you need to edit it before you open it you will need to delete the last few lines out which is telling pro to close
maybe someone inhere could enlighten us all which line is saying it is exiting exactly
then open it through tools play trail/training file
trail file is only usefulif you not saved the model during the session. More than two times saves in a session makes it impossible to retrieve.
Israr
In my version of trail files for WF3 with educational license, a close window looks like this:
~ Select `main_dlg_cur` `MenuBar1` \
1 `File`
~ Close `main_dlg_cur` `MenuBar1`
~ Activate `main_dlg_cur` `File.psh_close_win`
Though if you are writing the trail file yourself (to run in no graphics mode) you can lose those menu commands and just close the active window like this:
Similarly, a "Close ProE"/Exit looks like this:
1 `File`
~ Activate `main_dlg_cur` `File.psh_exit`
~ FocusIn `UI Message Dialog` `yes`
~ Activate `UI Message Dialog` `yes`
But I believe it will work with just the following two lines:
Don't forget to let ProE know when it's the end of the trail file:
!End of Trail File
Most lines with "!" at the start are comments but I think it's best to leave the end oftrail filecomment there and THE TRAIL FILE WILL NOT RUN without the first line which on mine is:
!trail file version No. 1350
But the "!" are good ways of leaving comment in the trail file if you are using for automation.
< 0 1.127111 1445 0 0 951 1920 0 0 1200 13
Are possibly mouse movements, but the trail files work just as well without them. (Usually, keep a back up just in case you delete too much!)
When things are continued on seperate lines, the first line has a \
at the end of it, to tell proE it's continued, e.g.
~ Input `new` `InputPanel1` \
`0001_STA`
Where it's slowly typing a dialogue box with a name in it. You can get rid of most of them too.
e.g.:~ Input `new` `InputPanel1` \
`0001_S`
`0001_ST`
`0001_STA`
`0001_STAI`
can be replaced with just the final two lines:
`0001_STAI`
Wheel and button clicks are also recorded, but are generally just scrolling or zooming so can also go:
~ Wheel `main_dlg_cur` `proe_win` \
9 265 373 458752 0 1529 947 1920 1200 302375
Same with:
~ LButtonArm `main_dlg_cur` `proe_win` \
9 367 44 0 1 1529 947 1920 1200 312063
~ Move `main_dlg_cur` `proe_win` \
9 367 44 0 1 1529 947 1920 1200 312078
~ LButtonDisarm `main_dlg_cur` `proe_win` \
9 367 44 0 0 1529 947 1920 1200 312172
Here's a final automation trail file I did for uploading new parameters for a design varient that a sales rep can email in. It works in conjunction with a config.pro file to maintain the paths whilst in ProE, a set of pre-existing models (with relationships programmed in), a Microsoft Outlook Macro, which saves the body of an email as a text file in the required path then changes a string of charactors in the trail file to a specific set from the email and finally calls ProE in the nographics mode to run the trail file before waiting for the PDF file to be written and then emailing it back to the sales rep.
All pretty simple stuff. Don't include the "=====" in the text file if you are running anything based on this.
-AS
!(c)2007 id2m, University of Liverpool written by Andy Southern
!mem_use INCREASE Blocks 14491, AppSize 93577864, SysSize 93734096
#DRAWING
#RETRIEVE
C:\ProE_filrs\generic_stll_ga.drw
~ Select `main_dlg_cur` `PHTLeft.AssyTree` \
1 `node0`
~ RButtonArm `main_dlg_cur` `PHTLeft.AssyTree` \
`node0`
~ Activate `main_dlg_cur` `OpenModel`
~ Activate `main_dlg_cur` `Utilities.psh_rels`
~ Activate `relation_dlg` `PBRead`
~ Activate `file_open` `Ph_list.Filelist` \
1 `1002_stll_param.txt`
~ Activate `relation_dlg` `TBVerify`
~ Activate `UI Message Dialog` `ok`
1 `stll_rel.txt`
~ Activate `relation_dlg` `PB_OK`
~ Activate `main_dlg_cur` `ProCmdRegenAuto.edit_t`
1 `node2`
~ Activate `main_dlg_cur` `File.psh_rename`
~ Select `rename` `RadioGroup1` \
1 `session_only`
~ Activate `rename` `rename`
~ Update `rename` `InputPanel2` \
`1002_STS`
~ Activate `rename` `OK`
1 `node1`
`1002_RS`
1 `session_only`
`1002_STLL`
1 `session_only`
~ Activate `main_dlg_cur` `ProCmdModelSave.file`
~ Activate `file_saveas` `OK`
1 `session_only`
`1002_STLL_GA`
~ FocusIn `UI Message Dialog` `ok`
~ Activate `main_dlg_cur` `ProCmdModelMkPdf.file`
~ Select `intf_pdf` `PDFMainTab` \
1 `PDFDescription`
~ Update `intf_pdf` `pdf_desc_title` \
`AUTOGEN STLL GA`
~ Update `intf_pdf` `pdf_desc_author` \
`AUTOGEN by AS`
~ Update `intf_pdf` `pdf_desc_subject` \
`DEMONSTRATION OF ProE AUTOMATION`
~ Update `intf_pdf` `pdf_desc_keywords` \
`Just a quick PDF to show what you can achieve with ProE (c)2007 id2m for quotation only`
~ Activate `intf_pdf` `pdf_btn_ok`
~ Activate `main_dlg_cur` `main_dlg_cur`
~ Activate `main_dlg_cur` `psh_erase_not_disp`
~ Activate `file_erase_nd` `ok_pb`
!End of Trail File
Israr
What about if you go back through the trail file finding the places where you've saved the file and delete them from the trail file?
It seems counter-intuitive that saving more often makes data recovery harder!
BTW: if you made the model in more than one session, you can chop and change the trailfiles so just search the content of the directory your trail files are in for the file name, and you can merge two trail files together manually.
-AS
Hi Andy
Imagine seeing you on here!
Interesting posts about the trail file stuff... wonder if the guy who originally posted ever got a solution.
Cheers
Edwin
