File Cleanup catvba program 5
cklong
Automotive
Dec 9, 2007
10
Hello
I made a catvba program that has been
very useful for me and I like to share it
with you. It's called File Cleanup.
There is 3 parts to this program.
Rename:
Is a search and replace,add to beginning or Add to End function.
That will go thru your tree and edit
Part Number,Instance Names,Properties Values or Parameters Values.
Example
If you needed your assembly Part Number to be 373225-"Detail Number"
instead of 373125-"Detail Number".
You would type in 125 in the search 225 in the replace.
Instance Names:
Allows you to select a product in the assembly and change the
Instance names to the Part Number,a Properties Value,Parameter Value or
to the name enter.
SAVE ALL AS PART NUMBER:
Saves the assembly in a folder you enter as the PART NUMBER name.
View Tree:
Allows you to view the tree structure and return to program when you are ready.
I hope you like it.
download.aspx
Good intention (you have a star from me for this), but for me cleanup means to follow my company's rules which can be completely different from what you are doing with this catvba.
Fernando
yes
Thanks!
i usually use New From..., but this may be useful too.
