What is the maximum size of a nozzle opening being welded per the figure in the subject line?
UW-16(d)(1)addresses necks attached by fillet or partial penetration welds but makes no mention of maximum size opening in the vessel.
UW-16(f)(3)(-a)(-2)states:"the maximum size of the opening in the vessel is limited to the outside diameter of the attached pipe plus 3/4 in., but not greater than one-half of the vessel diameter..." but that statement is for standard ANSI/ASME fittings and a different weld configuration.
I can't seem to find any maximum size opening for a nozzle neck into the vessel with a fillet on the outside and partial groove on the inside. Any information would be great, thanks!
