D
dakeb1
Guest
<DIV =wordwrap itxtvisited="1">Hi guys,<BR itxtvisited="1"><BR itxtvisited="1">I am trying to construct a figure-8 curve in ProE and have so far not found the right expression.<BR itxtvisited="1"><BR itxtvisited="1">The type of figure-8 curve I need is a full circle, constant radius throughout, i.e. two full circles tangential to each other (is it called a hippopede?)<BR itxtvisited="1"><BR itxtvisited="1">ProE can accept either a cartesian or polar expression. for cartesian I will need two expressions, one in terms of x and one in terms of y. For Polar it would be in terms of theta.<BR itxtvisited="1"><BR itxtvisited="1">Background: I have a sub-sea piece of equipment with a stowed cable. The cable is stowed by wrapping it around two parallel mandrels in a figure-8 helical fashion. I need to model the cable in 3D in its stowed position, so will sweep a solid circular shape along whatever curve is most appropriate. I reckon I can add a z-factor in ProE to generate the wound coils once I have the basic curve shape (at least I hope so).<BR itxtvisited="1"><BR itxtvisited="1">I'm not a mathematician, I'm a mech eng, so please keep it simple!<BR itxtvisited="1"><BR itxtvisited="1">Cheers,<BR itxtvisited="1"><BR itxtvisited="1">Dave </DIV>
