jayrod12
- Mar 8, 2011
- 6,277
Gents,
Seems like a basic question but I'm going to ask none-the-less.
I've got a current situation where a set of granite stairs is supported by steel framework. The steel is about 4 years old and is already showing significant surface corrosion. Generally this steel is enclosed in an non-accessible crawlspace that is likely high humidity due to inadequate ventilation.
I've already given the owner the "you should provide proper ventilation in here" talk but I'm fully expecting that not to happen.
Access was gained for review as the adjacent staircase is now getting a similar steel structure installed.
My question is, have any of you used a corrosion inhibiting coating that was successfully field installed on existing steel?
My first thought was they should be wire wheel/sand blasting the current steel, prime and then paint. Is paint enough or is there something heavier duty available?
For the new steel we will likely be applying the same coating due to the amount of field welding required there would be too many touch ups required to shop install a coating.
