Fiber Laser Build
Nidalap
Aerospace
Jul 18, 2017
4
I'm looking for a low powered fiber laser to attach to my CNC machine. Does anyone know any manufacturers of just the laser unit? I found some JSDU 2-5W units on ebay, but JSDU doesn't exist anymore and I don't want to buy something that I'll need to redesign if it breaks. Having said that, as long as I don't short circuit it with my shoddy electronics, I'm hearing that fiber lasers last 25,000h but then that's probably the top of the line units (but maybe it's not such a bad idea to get one of these obsolete units). Anyway, does anyone have any suggestions as to where I should be looking? I'm looking for lasers that are less than 100w.
Alibaba... plenty of Chinese shops willing to part with 20-30W fiber sources for a few thousand $s, $4-6k if you want a full stand-alone setup with optics and all.
Dan - Owner
Unfortunately, their work areas are too small, so they are of little use to me. The larger work area ones are too expensive, so ideally I'm looking to jerry-rig a laser to my CNC machine. I don't really care how quickly I'm able to engrave as long as it gets done... eventually and to a reasonable level of quality i.e. the laser needs to be somewhat precise. I spent some time on Alibaba, but couldn't find stand alone lasers, digging around google and emailing a few companies has also resulted in no leads. Alibaba apparently no longer has a sort by price option, so it seems it's now necessary to go through hundreds of pages manually... no thanks.
That's actually a good idea, frankenstein something, why not after all! Thanks.
That graph shows you all you need to know. A typical 1.06um fiber will work for Al, but it will be quite inefficient. WAY worse for copper. For copper, you really want to be in the green laser zone, but a standard fiber will cut through thin sheets with a slow enough pass.
Dan - Owner
