I want to couple nanosecond laser pulses of a q-switched Nd:YAG Laser into a usefull fiber. (pulse duration = 5ns, pulse energy = 20mJ)
To avoid fiber damage I have to use silica fibers of 600um core diameter. Can someone tell me what kind of coupling optics I have to use for this specification? The Problem is that because of the hughe core diameter the numerical aperture of the incomming beam has to be very low (assuming gaussian beam optics,which leads to long focal length. I have also heard that the input beam divergence angle must be higher than 30 percent of the fiber NA.
Thank you for help.
Thank you for help.
