we have to replace an existing heat exchanger ( a condenser using cold water ) by an air cooler ( fin fan), the elevation is about 4000 mm and we look to lift it to about 12000 mm,is is it possible to determine how this will perform the process, otherwise , between 4 m elevation and 12 m elevation, is there a real change, is it a way to optimise process conditions?
