fermentor sparger design
MSK1
AU
90m3 volume of liquid,air supply 4000scfm at2.5 barg,25 deg c temp.152mm pipe size,kindly suggest size and number of holes on sparger.
If 1/8" DIA. hole (3.2mm) drill 1792 holes
If 3/16" Dia. hole (4.8mm) drill 797 holes
If 1/4" Dia. hole (3.44mm) drill 448 holes
Hope this helps.
RESPECTED TURULATO,
Could u please apprise the way/method you arrived at the above answer.Relevent books/articles will do.
Thanks in advance
SALKO
Any air blower manufacturer will be more than happy to send you all the literature you need to design air spargers. You may want to contact hoffman for starters.
TRY THE FOLLOWING RELEVENT INFO.
CHEMICAL ENGINEERING MARCH 9,1981 ,116-117
CHEMICAL ENGINEERING APRIL 6,1981, 93-95
CHEMICAL ENGINEERING NOV17,1980, 277-281
SALKO
