FEMAP User Computed Vectors
rm_structural
Aerospace
Hello all,
First post so sorry if I'm breaking any rules.
To start, I am using FEMAP 2306 and am using the FEMAP function "Computed Vectors" to help streamline my work flow and am running into some issues. (Model > Output > Computed Vectors)
I've created a bunch of user defined vectors for typical outputs I use to design/analyze parts, but when the results are computed there are some irritations....
1)
The issue is that when FEMAP computes these, it does not use the titles I have specified. Does anyone know a way to make the "Title" stay as title in the results output vectors? Currently it will display the "Details" instead. This isn't helpful as I will screen shot many contour plots and the presentations only display the multiplications rather then the actual output. For example, it will display 1*7026+1*9026+1*13026.... etc. rather then "Plate Env Major Prn Stress" that I have dictated for that specific vector ID.
I know you can rename results manually, but I have many results as well as many output vectors, so this isn't feasible.
Does FEMAP have a setting that I can use to have the title generated as the output vector title as it is calculating/writing these? Seems to me that would be a common thing that maybe I am overlooking.
2)
I get a popup message for combining these vectors, which is much of an annoyance as it will not compute the combinatinos until I click through and select yes for all. Since I may have hundreds of results, this can be a big time waster.
Can I turn this off?
I've always used the default names... but I hope someone can help because I'm also interested on it
Hello!,
I see the same issue, here FEMAP developers is the only resource we have to get the title dominant in the generation of output vector, I will get them informed.
Best regards,
Blas.
