Background: I am in northern Vermont, constructing an accessory building. First floor is a slab and will be for small equipment storage, and tool storage. First floor will be heated. Second floor will be a finished guest loft (heated, water, etc.).
Foundation will be 6ft wall (to frost level), on an appropriate footing with drain tiles. My thinking is to place insulation and a vapor barrier under the slab. Two questions:
1. Given the first floor is not livable space, does insulation under the slab have any real benefit?
2. Is there value (to the building performance) in insulating any portion of the foundation walls?
Thanks,
Steve
Thanks,
Steve
