Features Not Following A Symmetrically Driven Part 1
TorsionalStress
234
Using CATIA V5R18;
I designed a left hand part and then created a right hand part with the “Paste Special, As Result With Link” function in a new part file. The problems that I’m having are the following;
1. I have a reuse pattern that doesn’t work in assemblies
2. I have threaded holes that doesn’t show up in drawings
Anyway to get all of the master features to show up in the slave files?
Any response will be greatly appreciated!
TorsionalStress, Right click over the left hand part and Create Technological Results. This will package up the feature information. In your symmetry part, right click over the linked solid body and Create Technological results. You should now have a list of holes and threads. This will be passed to your drawings.
Derek
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
Derek, the threads did appear but I was hoping to retrieve the features list so I can “attribute link” to them to get the feature size like from the original model, plus there is no pattern to chose from for multiple instances. Anyway this can be done other than remodeling a new part?
You can make a mirrored instance copy of the part. I use a script to symmetry the part around absolute X or Y zero. This can lead to geometric problems if the symmetry is applied around skewed x/y planes. This is not a big concern for me with the structure I have in place. I found the script sometime ago from Mike Berry but Ferdo has now placed it in his Portable Script Archive 2.0 You can find Product Symmetry under the product section of scripts. If you want to symmetry the X direction modify the lines to
'Invert x coord of part origin x direction vector
dblPosition(9) = -dblPosition(9)
dblPosition(0) = -dblPosition(0)
objProd.Position.SetComponents dblPosition
objProd.Name = "Sym X " & ItemToRenamePartNumber
End Sub
I added the above line to rename the product
First you make an instance copy of the product to symmetry. Next run the script. I have noticed that R20 step does not output the geometry correctly but iges does. I must be an undocumented feature of R20 because R19 worked fine.
Win XP64
Dell T7400 16GB Ram
