gageblockhead
Dimensions are in mm. What would the tolerance be for the feature control frame "3.730 8x" dimension? The block tolerance on the print is +/- 0.125mm. I am told that the print block tolerance does not apply. I have never seen T.I.R in a feature control frame for flatness or parallelism with a basic dimension framed for the distance. What is the tolerance of the 3.730 8x dimension?
