ahsanparvez
I am a new member to this forum.
I am working with a FEA program written in FORTRAN. I am analyzing the behavior of the reinforced concrete beams under constant amplitude cyclic loading. As for example: I am applying cyclic load range between 30 kN to 100 kN till the failure of the beams. I am recording the total number of cycles till failure and load versus deflection relationship as well.
Problem:
The deflection under maximum load (100 kN) is reasonable. Whereas, the deflection under minimum load (30 kN) at each cycle is underestimated in FEA, meaning that I am getting less deflection value than actually it should be. It indicates that the FE program is overestimating the elastic recovery during minimum load, thereby giving lass deflection.
I understand that I have given a general view of the problem and may be difficult for others to get full picture of the problem. However, if anyone can give me any hint I will be highly obliged.
Problem:
