FEA on ABS material
  • Thread starter Thread starter cadharts
  • Start date Start date
C
cadharts
Guest
Hello, just had a design where the material to be used is ABS plastic and I wanted it to test it's strength and optimize the design. with this material there is no Yield strength because of it's property and that is one consideration for von mises stress. How can i make it stronger and test it's weak areas and create support? Do i use the stress where the part breaks??
hi,
what it did was to create a new material, copied its physical properties, and added its yield strengh which i found in the internet (its 65 N/mm^2).
good luck,
joel
Hello, thanks for the reply. I was planning also in creating a customized material. But how come there is no value for the default SW material? Also, the tensile strength of ABS is about (48 N/mm^2) which is lower than the yield strength, unlike steel material which is the opposite. Maybe you had triedand had your thoughts on this. Thanks.
Hi cadharts
I suggest you to use Ansys 12 which have very good optimisation module + material properties from matweb...
Valery, jbiplane@gmail.com
