HonzaS
- Nov 5, 2010
- 21
I'm looking for node to node contact in NX Nastran.
I've found CGAP elements, but I dont't know how to work with it excactly.
Do you have any experiences with them?
I've managed to run a very simple model, that runs with CGAP elements instead of surface to surface contact and results are similar. But the CGAP version does not iterate (is it necessary to run nonlinear solver to force it to iterate? - updating gaps). // picture in the attachment
I need it for a complex calculation, where some certain parts are simplified just for stiffness and are modeled manually (excactly node to node in contact areas) and I want to make it as simple as possible.
Thank you for any help or suggestion!!
