engroma
- Nov 1, 2008
- 14
Hi
I am modelling a part in which I have to bond with an adhesive a metal block withstanding a load.
To model the adhesive I figured different options
1) merge the nodes in adhesive areas
2) simulate the adhesive with elements
3) using spring elements between the two adherents
4) to use the laminate propriety of Femap and using like core the metal block
What is the best solution in your opinion? Where can I find some example?or do you have better idea?
Engroma
Engroma
