Fatal error
Firerunner
My company just upgraded to 2007. It works fine unitil I try to import a profile. the profile works fine until I leave the program.When I open AutoCAD again I get a fatal error and it shuts down. The only way can get it going is to uninstall and reinstall.
Has anyone run into this problem.
The only reason I use profiles is so I don't have to keep typing directories into the Support File Search Path
Thanks for any help
I added this in our ACAD.LSP file so it ensures that a support path is available when AutoCAD starts. Might help you?
;AddSupportPath:
;Example: (ADD_SUPP_PATH "C:\\PROGRAM FILES\\ACADM 6\\SUPPORT\\CUSTOM")
(defun AddSupportPath (PATH / FILES PATHLIST)
(vl-load-com)
(setq FILES (vla-get-files(vla-get-preferences(vlax-get-acad-object))))
(setq PATHLIST (vla-get-supportpath FILES))
(if (not (vl-string-search PATH PATHLIST))
(progn
(setq PATHLIST (strcat PATHLIST ";" PATH))
(vla-put-supportpath FILES PATHLIST)
) ;progn
"Everybody is ignorant, only on different subjects." — Will Rogers
Similar threads
