I am looking into fastener GK Joint Analysis and I am checking that fasteners connecting LSection to side skin on upper side of skin as shown in picture has Nx,Ny, SumNx,SumNy ,qxy loads.I am considering SumNx,SumNy loads for calculating MS for fastner.I am noting that GK Joint is calculating negative MS for tension/bypass bearing and also negative MS for bolt bending.Also there is warning message:
THE DIAMETER EXCEEDS THE VALID RANGE FOR THE BEARING STRENGTH DIAMETER FACTOR.VALUES HAVE BEEN EXTRAPOLATED.
Please advise what could be cause of this negative MS and possible action to fix same.
