pipedesign
I have a problem that I don't understand !!!
I am useing a FCU (vertical cabinet) to cool the air in the summer and to make it hot in the winter !
The FCU I am useing is in the 2 pipe chage over system, so the coil is used by the cold water (7-12 grdC) and by the hot water (80-70 grdC) !
Here is the problem : my room need the same quantity of heat in the winter as it need in the summer : 1000Watt ; but the FCU provides me in the summer 1000Watt and in the winter 2500 Watt minimum !
How do I solve the problem? I dont need that much heating capacity in the winter !
Can I use this FCU ? Can I make it work in the winter at 1000Watt ? What are the implications ?
I must also say that I cant use the 4 pipe system, with separate coils for winter and summer !
Please help me , cos I'm in a big dilema !
Thank you very much !
