family table
  • Thread starter Thread starter manojnaik
  • Start date Start date
M
manojnaik
Guest
Hi everybody,
I have problem I want to give family table values in associated table in detailing But not all the dimensions some dimensions (I mean some columns) only I want show. Is there any technique?
Yes there is. You need to create a table then Simple Repeat Regions (one for each column). You will then have to enter the appropriate Variables and Filter the columns to display what you need. Its really to much to get into in this forum, but you may find the directions on PTC's knowledge base. Its at the following URL:
http://www.ptc.com/cs/cs_23/howto/dwt_no2d/dwt_no2d.htm
