FAMILY TABLE COLUMNS
  • Thread starter Thread starter SANCHA
  • Start date Start date
S
SANCHA
Guest
How can I reorder in my drawing the collumns sequence from a family table previously defined?
Do I have to change this in drawing or in part?
How to do it in both cases?
Depends on what kind of repeat region you have in your table.
If you used 'Two-D' repeat region, the order of column is as same as in model, therefore any changes you need to make in the model.
If you used 'Simple' repeat region, order of column is independent of model.
In this case, you probably have filters set in these regions.
To change the column, just change the filter value.
