I want to model some hose assemblies but I have the same hose part number being used in different locations on the top level.
I could for example call one the assemblies [part number]_1 and the other [part number]_2 but I would probably still have to have a third assembly showing the hose laid out straight to generate the drawing. The better option seemed to me to create a Family Table with the hose ends in different positions in different instances (I don’t mind if the hose has to have a different part number in CAD for the different routed installations). However, the only way I have found to have the hose ends in DIFFERENT position in the instance to the generic is to deled the parts out of the instance and then re-insert/assemble them. This results in a supressed copy in the generic assembly which won’t go into Intralink.
How can I have an instance of an assembly with the hose ends in different orientations, but avoid the above problem. Surely there must be a way of breaking the tie between the constraints of the part in the instance from those in the generic???
Please help! Thanks.
