Family Part for another family part?
Kenja824
Automotive
Gonna be hard to explain this so please bear with me....
Im making a palette with common assemblies. For instance, it can have a riser, a clamp, clamp arms, shims and a couple solid bodies they can steal for a head start on make details, as well as all of the screws.
The clamp and the arms as well as the riser will each be the actual Family Master.
The designer will bring a common assembly into his tool and position it where he needs it, and simply drag the items he wants into his tool. This way he gets several components at the same time and they are all in position already. Only smaller adjustments will need to be done. The solid bodies can be copied and pasted in as well so he has a head start on make details. The Family Masters allows him to replace components and just select the same part and it automatically opens the family parts options so he can bring in the exact clamp or clamp arm or riser he needs. He does not need to go through the paths to find the Family Part Master.
My problem is that the family master of the Clamp Bodies has three different series of bodies in it and each series has maybe 20 options. Because the three different series of clamps are such a disparity in sizes I would rather make a Palette tool with one series another palette tool with another series and a third palette tool with the third series. But I cant separate the series from the current Family part of clamps.
I had a thought of creating a family part that did not make new clamps, but only called the family members I choose. In other words, the current Clamp Body family master created all of the members and they are in a Child directory right now. Is it possible to create a family part that does nothing more than call family members that are already created?
I know you can add components to the spreadsheet, but to my understanding the end results is it makes a new family member with that component inside of it. I dont want to create new members. I only want to pull already created members.
Does that make sense?
You are not correct. The part family will not make new members of the components. It uses the original ones.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
How does that work, can I ask? On the spread sheet, do I just give it the same OS Name as the component we are calling? I was expecting that would cause it to try and make a family part with the same name as one that already exists and cause an error.
Doesnt matter. I will try it and see how it goes. lol
Yeah this is what I thought would happen.
I don't think you are understanding exactly what I am trying to do. Or I am not understanding how I am to do it. lol
I don't want to create new family members with the components inside of them. I just want it to retrieve the family members that are already created. Not as part of an assembly. The original family master has about 60 members it created. I want to put a file in an assembly that gives you a choice out of only 20 of them.
I would just split that one family master into three different family masters. One with the 50 series, one with the 60 series and one with the 80 series. The problem with that is in order to create the members with the same names, you need to delete the originals first. Which then leads to a problem with all of the tools that were using the originals will no longer load the component up. Even though you create a replacement with the exact same file name in its place, the tools somehow still recognize it as being different. So every tool then needs to be changed manually.
Then I misunderstood. This functionality only works when the components are part of an assembly.
NX9 / TC10.1.2
