I want to use failure criteria other than Von Mises in the visualiser or even just post processing. Normaly the failure theories are quite simple like Coulomb-Mohr theory:
max princ stress divided by materials UTS minus min princ stress divided by UCS. Fracture occurs if the answer is equal or greater than 1 (but you all knew this anyway)
Can i create a result set that applies formula like the one above then display the result set to see if fracture has occured. I have never created any result sets and i got a bit lost when i tried. I would like to know if i'm on the correct track before diving on in!
Many thanks in advance
Using ideas 9
Using ideas 9
