Failure Analysis?
dursosono
Materials
Aug 6, 2008
59
Does anyone know, what happen in this material?
What type of that corrosion?
How can this occurs?
This is flowline with some data
-Material : NPS 4, API 5L-B, Sch 40
-Remaining thk : average 1 – 2 mm
-Date of construction : July, 2006
-Operating pressure : 225 psi
-Operating temp. : 80 F
-Service : Gas
-Flow rate : 1.5 – 2.0 MMCFD
-Distance from wellhead : 1.5 Km
-Position of corroded area : 6 O’clock
-Date of failure : Dec, 2008
I had similar problem once where water in the stream condensed and reacted with CO2 in the stream to produce carbonic acid. You need to provide more info as to stream makeup.
Looks like classic CO2 corrosion but should be confirmed by an review of process conditions and a laboratory examination. Sticking a picture on Eng Tips, although pretty, is not the way to undertake failure analysis!
Steve Jones
Materials & Corrosion Engineer
