failed to save
hotiron
79
Hi all,
I've been getting a "failed to save" error when trying to save assemblies. I seem to remember seeing this before and got a macro to force rebuild all subs prior to save. It seemed to work for a while until now.
Has anyone seen this error?
dg
"failed to save" search proved fruitless.
JM
I work locally and save often. Up until now, a full rebuild solves this issue. The only connection to the network, in this case, are some toolbox items. Does "transient" mean the problem comes and goes randomly? Thanks
If you are using configurations, cycle through all of them, explode all your explosions and collapse them, go back to Default config and force rebuild, then save.
This procedure has saved my a$$ more times than I'd like to admit. IF this doesnt work, then good luck. I know there are a couple of procedures people do to remedy it. however, up to now I still dont know exactly WHY it does it.
Here's a page on this issue, you'll find plenty of fixes there.
SW2008 Office Pro SP4.0
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
The solution is to save early and often, unfortunately. I am using 2007 and never saw the error until this year (ironically a couple months after I first heard about it). It is frustrating to say the least.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
Curious, do any of you experience this problem that make use of a PDM System? I've been told by our VAR that a PDM will solve this problem, as it elliminates the basic problems with collaboration mode and / or the inherent problems with file locking at the OS level. This, BTW, is a strong selling point for people who are considering moving to a PDM from basic SW Collaboration Mode...
M.B. Price CSWP
Automated Assembly & Test Systems
I worked at a place that used DBWorks, and I think we had that issue with both SW2006 and SW2007 (latest versions I used there).
Ken
I've had this warning happen to me while working on PDM and off PDM, on networks and off networks.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
I have seen the failed to save error if the network drive was almost full.
I haven’t seen this error of a long time, and then yesterday it happened to me twice >:-<
Jim Self
SW2008 SP1.1
Dell Precision 670
3GB Ram
Quaddro FX 3400/4400
dlplimited.com
