Failed to save - NX6.0
jackley
Automotive
Sep 2, 2004
263
N:\Packaging\1062021.prt failed to save (when trying to save N:\Packaging\1062021.prt) with code 1020199 "Unrecognized operating system error see syslog"
Anyone get this error while saving? The other designers have seen this error in the past and they try saving a second time and it works. This time it's not saving.
Any ideas?
Justin
Justin
Designer
Sounds like you're saving to a network mounted volume. If that's the case, it could have been a problem with the network connection, which is why a few minutes later everything worked. I don't think it has anything to do with NX or the parts which you're trying to save.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Don't take my word for it because it is risky and I can't vouch for what error messages I got, but on occasion I have experienced cases where the system said it hadn't saved a file, but it had. In general I'd try to save my work in another location, and I certainly shut down the session straight afterwards. Maybe it is even advisable to re-boot your computer under these circumstances. However while running under native I found my assumption that my work may have been lost was contrary to what the error/warning message suggested.
This has occurred on a couple of rare occasions only, so I now tend to check folder contents whenever I get such messages, or even open another session alongside so I can open the saved data and check if it is okay.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
John, you are correct. They are saved to a network drive. I was certain it had nothing to do with NX, but wanted to see if anyone else had encountered this.
Hudson, I have had that same issue. Kind of odd, but I do the same and sometimes even reboot.
Thank you.
Justin
Designer
