But, where's the analysis for hydrogen???
Were the parts ordered to be processed per either MIL-DTL-13924D or AMS 2485J?
MIL-DTL-13924D COATING, OXIDE, BLACK, FOR FERROUS METALS.
“3.2.1 Stress relief. Unless otherwise specified for a particular end item specification or drawing, after forming and hardening, and prior to cleaning and coating, objectionable residual stress in ferrous alloy parts having a hardness greater than 40 HRC shall be relieved by suitable heat treatment.”
“3.3 Application of black coatings. The coating shall conform to the class specified. The specified black coating shall be applied under controlled time and temperature conditions. All equipment together with solutions or baths shall be properly maintained and kept free of dirt or possible contaminants. The selected process shall not reduce the hardness of the parts being processed or expose the parts to temperatures in the temper brittle range of the material, nor shall it cause embrittlement of the steel.”
“3.10 Hydrogen embrittlement relief treatment. Steel parts that are surface or through hardened at 40 HRC and above shall be given a hydrogen embrittlement relief treatment after application of the oxide coating. Coated springs or other parts subject to flexure shall not be flexed prior to the embrittlement relief treatment. If an embrittlement relief treatment is required, it shall follow the chromic acid rinse. The embrittlement relief treatment precedes the supplementary preservative treatment.”
A typical black oxide process sequence for (non-stainless) steels is:
alkaline degrease, rinse,
hydrochloric acid pickle until all rust is removed (so if some rusty items processed in the same hoist load with your basket of bolts, lots of hydrogen), rinse,
hot black oxide, rinse,
dilute chromic acid rinse (per MIL spec but optional in practice),
water-displacing oil.
