alienitmeca
Hello everyone,
I am elborating a datasheet for a control valve to be used in fire fighting project. While researching, I came across the term "fail mode" which means that I should choose whether the valve is going to be either open or closed in case of power failure (according to process).
After discussing with some suppliers, I understood that adding this cretria to the valve will increase its cost.
My question is as follows:
- Is it obligatory to have a fail mode for the valve in this appllication (fire fighting project) ?
- Does any NFPA code specifies it or at least mention it ?
