Tucker had the center headlight turn with the steering.
Regarding the question.. unless there is airflow seperation downstream we're looking to minimize, dimples and vortex generators create a lot of unnecessary drag. Compare a flat smooth panel under the car, and one with 80 vortex generators sticking out... may help in certain instances, but unless properly engineered, it will likely be a negative. We're trying to create low pressure under the car, and the extra turbulence may not help too much if you know what I mean.
Regarding the golf ball... let's model vortex generators on a golf ball and compare it to a dimpled golf ball!
