I have seen a few threads on facet bodies, but none of which have helped me, unfortunately.
I have large assemblies of components made up from parts from Ideas. I have exported the components into one part file, (for ease of manupulating without having to constantly change the work part) and now have ~14,000 facet bodies within that one part file.
Firstly, I assume the reason that they are all facet bodies is because they were imported from Ideas originally(?)
My problem is that I want to trim some of the bodies. As they are facet bodies this is not possible. I have tried using the various tools that are suggested in other threads ("Rapid Surfacing", "Refit Face") as well as exporting as IGES/STEP and even JT (in an attempt to use the "Extract Exact Data" command under File, Properties - which was greyed out) and also using "Extract Feature" underneath Insert, Facet Body. When trying to use any of these, it does not let me select any Facet Bodies, meaning that I can't do anything.
Please can somebody put me out of my mysery?!
