Having 20y experience in making small dia tubes of various materials using "free extrusion" technique. Recently met a challange: to make a HDPE tube 6mm OD, 5mm ID on 38mm (1.5") extruder with flex PVC screw. Though screw seems to handle the material, thin wall collapses in cold water bath. Air pressure inside doesn't help. The tube doesn't have to be perfect round. Would a hot water bath precooling help or any other tricks available? Thanks!
