Z
Zestje
Guest
I have IGES data converted from ECAD files. Fhe file contains a few hundred simple rectangular blocks. After importing the IGES into an almost empty part, ProE becomes -extremely- slow when interacting with the import feature. When I select the import feature ProE freezes about 2 minutes before anyting happens. I don't know why.
The only thing I have found which might have something to do with it, is that for each block (ECAD component) a layer is created which contains the surfaces of each block. Maybe that's just too much for ProE. I haven't had the chance to test that yet.
Does anyone know how to prevent this from happening?
Thank you for any help...
