extracting results from transient structural analysis ansys workbench
mayakuntla92
IN
i want to extract nodal velocities at some nodes at all time steps (transient) to csv or dat format directly. i have written this code
SET,LIST
*DIM,VELY,ARRAY,3125,800 !!!!! FOR 800 NODES AT 3125 TIME STEPS
NODENUMBER=141475 ! INITIAL NODE NUMBER
*CFOPEN,VEL,CSV
*DO,KK,1,800,1
*GET,VELY(1,KK),NODE,NODENUMBER,V,Y
*VWRITE,VELY(1)
(E15.8)
NODENUMBER=NODENUMBER+1
*ENDDO
*CFCLOSE
still i am unable to extract results?? any help
have you tried something like this (only for the last time step)
Code:
*GET,NCOUNT,NODE,,COUNT              ! Get total number of selected nodes
*DIM,VELY,ARRAY,NCOUNT,1             ! Create NCOUNT x 1 array
/POST1
SET,LAST
*CFOPEN,VEL,CSV                      ! Create file called vel.csv
*VGET,VELY(1,1),NODE,1,V,Y           ! Fill first column with vy
*VWRITE,VELY(1,1)                    ! Write one column to file
(E13.5)                              ! Format with scientific
*CFCLOSE
Think it is not easy this - how you going to distinguish when one node history stops and the next starts.
The normal thing is ti generate a time history file for every node. Thus if we have 200 nodes, we generate 200 files.
That can be read in automatically in in a small script. One can also append it to the same file using the append option in cfopen.
I have not managed to do this 100%, but have a go and see if you can get it to work:
Code:
/PREP7
ET,1,BEAM188
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,1,,7800
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,200E9
MPDATA,PRXY,1,,0.3
SECTYPE,   1, BEAM, RECT, , 0
SECOFFSET, CENT
SECDATA,0.1,0.1,0,0,0,0,0,0,0,0,0,0
K,1,0,0,0
K,2,2,0,0
L,1,2
LESIZE,ALL,0.1
LMESH,ALL
FINISH
/SOL
D,1, ,0, , , ,ALL, , , , ,
F,2,FY,-1000
ANTYPE,4
TRNOPT,FULL
LUMPM,0
DELTIM,0.1,0.1,0.1
OUTRES,ERASE
OUTRES,ALL,ALL
AUTOTS,1
ALPHAD,0.11
BETAD,0.00025
KBC,1.0
TIME,2
TIMINT,1
SOLVE
/POST26
/NERR,2000
*get,ncount2,node,,count
*do,i,1,ncount2,1
NSOL,5,i,V,Y,
STORE,MERGE
*GET,size,VARI,,NSETS
*DIM,VEL,ARRAY,size
VGET,VEL(1),5
a='filev'
b=CHRVAL(i)
c=STRCAT(a,b)
*CFOPEN,c,dat         ! If appending, just use one file name, say a and use append so: *CFOPEN,a,dat,,append
*VWRITE,VEL(1)        ! Write array in given format to
%14.5G
*CFCLOSE
*DEL,ALL
*enddo
Thanks for the reply guys.
Dear jkupka84,
just now I executed your code for postprocessing. there were no errors. thanks for your code. your code is writing velocity in y-direction for node number 1 at last time step successfully.
how to write at all time steps???
set,last --- gives only at last time step
from the scratch try something like this
Code:
/POST1
SET,LAST                             ! Read the last data set
*GET,NTIME,ACTIVE,0,SET,LSTP         ! Get last data set number
*DIM,VELY,ARRAY,NCOUNT,NTIME         ! Create NCOUNT x NTIME array
*DO,i,1,NTIME                        ! Do-loop over NTIME
 SET,i                               ! Read the i data set
 *VGET,VELY(1,i),NODE,1,V,Y          ! Fill first column with vy
*ENDDO
*MWRITE,VELY,VEL,CSV,,JIK            ! Writes a matrix to a csv file in formatted sequence as NCOUNT rows and NTIME columns
(xxE13.5)                            ! Format with scientific where xx is NTIME scalar parameter which you have to change manually
I don't know if is possible to do it without hard coding of xx. Maybe do-loop of each matrix element separately.
