Greetings,
I am trying to extract Magnetite from ordinary sand using a somewhat unique design involving electromagnets. I don't have much experience with magnetic engineering--so I thought you guys could help me out.
Here's the gist of the process: (I also put this online here for better viewing)
Setup...
- Two electromagnets with metal plates are fixed apart with a gap between.
- The electromagnets are powered by a car battery and controlled through a relay by a laptop (over the lpt port).
- The laptop can then independantly turn each on and off.
Execution...
- Magnetite laden sand (5-10%) is poured in a steady stream between the electromagnet plates while both plates are activated.
- Almost all magnetite will cling to either face, and the rest of the sand will be collected.
- The magnetite extracted will only be about 75% pure--other sands will be swept up in the processes and become attached to the plates.
- To remove this sand, the laptop turns on and off the two electromagnets in quick alternating pulses.
- The excess-sand should be shaken out and the remaining magnetite will be purified as the magnetite is thrown between the two plates.
- The excess sand will be discarded and the magnetite will be released into another container by turning off both electromagnets.
My questions:
* How should the electromagnets be designed? I need them optimized for a strong force over the entire face of the plates. Number of turns, gauge of wire, length of pole, pole face area, are all variables. I would like to wind my own.
* What power source should I use? --car battery? 12V, 350W Computer power supply?
* Do you think this will work?
Thanks for your help!
Setup...
Execution...
My questions:
