HI
Thank you 76185 ,
As you have said i found the related code lines in examples.
What should i do now for solution mapping? I consider next steps as follows :
remesh the deformed shape and introduce boundary conditions and loads once again
write input file and add * map solution and step and increment numbers to it
Now , how should i make abaqus understand from which job and database should it read the nodal values and map it to new job?
Thank you very much for you help and
Best regards
