Extracting energy from low pressure flow
AdamJ2
GB
Hello Everyone,
I would really appreciate if anyone has ideas on how to extract energy from low pressure flow. The situation is that I have horizontal water flow in a pipe with a working pressure of 1.5 bar and I need to figure a way to convert some of the flow into a useful energy form such mechanical (rotation) or electrical. My first thought was to use a hydraulic motor but I quickly realise that these devices only operate at at least 10 bar. I'd grateful for any help.
Some form of waterwheel or vane pump running backwards. But you need a lot of flow to get anything useful.
Pneumatic motors are designed to run on low pressure. Parker and Globe are two brands.
They probably don’t like water though.
How much flow do you have? Can you accelerate the water with a nozzle and use a pelton turbine?
Do you have enough flow to be able to boost pressure with a ram pump, store the higher pressure in a tank and then extract energy from that with a higher-pressure system?
What would you use if you had flow with a higher pressure?
What is the application? Personal? Work? Hobby?
Engineering is not the science behind building. It is the science behind not building.
Hello everyone,
many thanks for everyone who provided suggestions, sorry for not replying I was quite ill and couldn't work for the past few days.
hydtools, IRSTUFF & littleInch,
I quite like this suggestion. although I couldn't find a suitable waterwheel I am going with a water trubine (shown in the photo) which hopefully will do the trick. Out of curiosity, does anyone know what happens if I use a 10W water turbine with a flow powerful enough to power a 150W, would there be H&S risk?
Jacc,
thanks a lot for the suggestion, I;ve looked into this but I don' think it will work with water.
itsmoked,
great idea, I'll investigate this prospect further but I think my flow might be too weak.
EngineeringTex,
thanks a lot for you comment, unfortunately I can't use a nozzle in my application. I quite like your idea with the pump and tank and I'll see how I can apply it. I'm currently using a small tank to reduce flow fluctuations but I haven't considered using a pump so thanks. If I had a higher pressure I'd simply use a hydraulic motor but all the ones I found only operate relatively high pressures (at least 10-30 bars). My project is work related so I have a budget to try things out but it would of course be best to get it right the first time.
thanks again everyone
You just won't get the flow.
You have as you say 1.5 bar - that 0.15MPa. When you look up those minim wheels you'll get about 10V if you're lucky and virtually no current.
1.5 bar is what you get from most domestic supplies in Europe or the UK - maybe more in the US but I was astounded by how many options came up for the F50 80V pump.
An interesting demo here:
Hi LittleInch,
yeah I agree seems like the wheel won't reach anywhere near the advertised 10W which isn't much to begin with. nonetheless I've ordered a couple since they're very much and I'll see how it goes. Also thanks for sharing the video demo, I didn't realise these water turbines were actually popular.
Looks like people are trying to get power from their domestic water supply.
The efficiency looks terrible so you will use a LOT of water.
I don't have any idea on the amount of water that is available, however, research the Banki hydroelectric cross flow turbine. There is a fair amount of information and research on this turbine.
