Can one create a Macro that would extract data (dimensions, tolerances, maybe even notes) from a drawing and place it in an Excel Spreadsheet? Does anyone have anything like this that they would be willing to share?
This will create a file on your C:drive called Annotations If I had more time I would try to get it to excel but this will open in note pad.
'Paste the following code into a new macro file
Global swApp As Object
Global Document As Object
Global boolstatus As Boolean
Global longstatus As Long
Global SelMgr As Object
Global PickPt As Variant
Global Const swDocDRAWING = 3
Sub main()
Set swApp = Application.SldWorks
Set Document = swApp.ActiveDoc
If Document Is Nothing Then
MsgBox "No model loaded."
Else
FileTyp = Document.GetType ' Get type
If FileTyp = swDocDRAWING Then ' If doc = drawing ?
SheetNames = Document.GetSheetNames ' Get sheet names
Document.EditTemplate
Document.EditSketch
Document.ClearSelection2 True
Set fs = CreateObject("Scripting.FileSystemObject")
Set a = fs.CreateTextFile("c:\annotations.txt", True)
For i = 0 To Document.GetSheetCount - 1
Document.ActivateSheet (SheetNames(i))
Set View = Document.GetFirstView ' Get first view
Set Annotation = View.GetFirstAnnotation2 ' Get first annot
While Not Annotation Is Nothing 'When a valid annotation is found
If Annotation.GetType = swNote Then 'Check if annotation a Note
Set note = Annotation.GetSpecificAnnotation
revnoteval = note.GetText
a.WriteLine "note=" & revnoteval
End If
Set Annotation = Annotation.GetNext2 ' Next annotation
Document.DeleteSelection True ' Delete selection
Wend ' View is valid
Next i ' Next sheet
If i > 0 Then ' More than 1 sheet
Document.ActivateSheet (SheetNames(0)) ' back to 1st sheet
End If
End If
End If
Document.EditSheet
Document.ForceRebuild
a.Close
I created a new macro and inserted your text into the macro window. I'm new to SW and creating macros, what must I do next to run the macro?
I appreciate your help.
Is this correct?
Dim swApp As Object
Sub main()
Sub main()
Else
Document.EditSketch
End If
Next i ' Next sheet
End If
End If
End If
Document.EditSheet
a.Close
Delete the first two lines and the last two lines. To run the macro: In SolidWorks, Click on Tools, Macros, Run and then browse to your macro. Then just go to your C drive to find the file annotations.txt To put the file elsewhere just change the path of the file inside the macro.
