Extract geometry-shaded view
geo12
CA
I have a problem with shaded view of an extracted surface of a solid.
While it is in rotate,zoom or pan mode, I am getting a square and rectangle like shade on the screen for few moments after the mouse is being released.
This problem is only with the extracted surfaces.
When the solid is rotated,the shaded views are very sharp and clear.
Any solutions please. Anything with the configuration of default settings?
Preferences
Visualization Performance (?)
Large model
There is a check box that when you rotate/zoom/pan models, they turn into blocks for faster refresh.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
hi Geo ,
as looselib said go to
preferences-->visualisation performance-->large model
in that there is a scroll.make it to minimum.
The scale will be 1-20.Make it to 1 .
U will not get the rectangle like thing ,
Thanx,
Karthikeyan.J
Under "preferences-->visualisation performance-->large model" be sure that you don´t "have fixed frame rates" box checked. If the setting is turned it can cause lagging and boxiness due to lack of graphic power.
Thanks all of you.
It works..
Wish you all a happy new year.....
