EXTERNAL PADS IN PRESSURE VESSEL ASME DIV XIII SECTION 1
Facundo9788
This is my firt entry.
I work designing and drafting vessels according to ASME DIV XIII Section 1 and the European Union Pressure Equipment Directive (PED).
I searched the ASME Code for grounding/earthing lugs an I didn't find specifications, then I searched the API 650 and found something but it is way to big for what I need, at least I saw that the lug must be Austenitic Stainless Steel no matter the vessel material. For welding then I must go for a 309L electrode if I combine Stainless and Carbon Steel.
What I really need to know and I didn't find and answer in the Code is: a pad, like the pad of a saddle, is considerer a pressure part UG-4(a) or a non pressure pad UG-4(b)?
What consideration shall I have for welding the grounding lug to the shell or to a pad welded to the shell?
Facundo.
IMO, there is no issue to locate the grounding lug on the non-pressure part of the vessel, such as vessel skirt or leg. Right?
It's true but my regular designs are vertical scrubbers with elliptical cap on top and flat welded cover in the bottom, bolted to a skid or frame, both the shell and the flat cover are pressure parts UG-4(a) so what I want to do is when I have a Carbon Steel shell attach a welded carbon steel pad and then weld the lug to the pad to avoid a special WPS and WPQ.
See PIP STANDARD DRAWINGS VEFV1103 Vessel Grounding Lug
Facundo9788, you may do so if you wish. By the by it is Sec VIII, Div 1.
Mike
