BridgeSmith
Please forgive me if my terminology is off a bit. I have a cable approximately 120' long, composed of 4 wires that are stranded wire of either 8 or 10 gauge, which I would like to set up to carry 2 household 110V AC circuits. For reference, it has black, red, white and green, in a rubber outer sheath, similar to a typical extension cord.
Question 1) If they're not labeled, how do I determine the gauge of the wire? It probably won't matter, since I only plan on 20A circuits, but I'd like to know what I'm dealing with.
Question 2) Is there an acceptable way to connect this? I was thinking of two options:
Option A:
Black - Hot #1
Red - Hot #2
White - Neutral #1 & Frame ground #2
Green - Neutral #2 & Frame ground #1
Option B:
Black - Hot #1
Red - Hot #2
White - Neutrals #1 & #2
Green - Frame grounds #1 & #2
Will one of these 2 ways work, is there a better way, or should it not be done?
Option A:
Black - Hot #1
Red - Hot #2
Option B:
Black - Hot #1
Red - Hot #2
