I'm working on a project that requires some 36" and 42" gate valves (low pressure, normal temp, basically water 150# service). We have to bury the lower half of the valves around 1.5m-1.8m in the ground and the client is not going to build a caisson around the valves. We want to use an extended bonnet valve in order to have a valve that can be half-buried and still keep the exposed part of stem and packing above grade.
Does anybody know if there is a manufacturer who can actually supply information on length up to the packing so we can determine suitability? Our critical height is from the valve centerline to the top of the packing and I've been having a difficult time getting this information so far. Standard catalogs tend not to cater to the extended bonnet versions.
Are there other options worth considering? I've seen some options for double shell enclosed gear extension type valves, but I'm not sure how those would be to service the packing years down the road if needed.
