Expresseion
Tools, Expressions
From there you can create a name for your blend, ie Blend, and give it a value, either a number, or an equation.
Then when putting in the blend, use the word Blend, and it should use the value you gave it.
-Dave
NX 9, Teamcenter 10
You need to use interpart expression
The syntaxe is in core_side.prt
blend=1.5*cavity_side.prt::blend
Didier Psaltopoulos
small mistake, the syntax is:
blend=1.5*"cavity_side"::blend
NX10 menu
NX11 menu
Didier Psaltopoulos
Thanks Didier Psaltopoulos
Girish.
