W
wibble
Guest
Hi there,
I have just joined the forum and have an urgent question regarding exporting surfaces as stl format. I have tried a few quick searches but they turned up nothing.
1.) I am trying to export surfaces and not solids as stl, ProE (2001) seems to have a problem with this and doesn't do it. Can this be done and if so how? Since the STL format is a surface mesh format I find it incredible that it can't do this, although I can perhaps understand the need for sealed volumes. Are there any quick workarounds to this issue?
2.) When trying to export some solids as stl there appears to be a limit on minimum Chord height that can be set (I need very small values). Is this the just the angle control tolerance holding it back?
Thanks for you help!
