Hi
I'm working on a multi level concrete structure modeled on etabs. Two columns supporting level 2 slab are transferred on level 1 slab.
We have exported level 1 slab in Safe but the transfer point loads from the columns are not there. I'm sure that this is a mistake from our end but we can't figure out how to export the floor in safe including the transfer point loads or line loads calculated on etabs.
Looks like that we have to manually copy the loads from Etabs to Safe. I can't believe that this is what we have to do. Etabs and safe talks to each other so I expecting to find all the transfer loads on top of the slab.
It's pretty common to have transfer loads on top of a slab, when exporting to safe the loads should be there ready for the slab design.
Hopefully someone can help me out with this.
