Exporting point information
  • Thread starter Thread starter proed
  • Start date Start date
P
proed
Guest
Hi.
We have a complex assembly with hundreds of points in the components (placed along helical paths, etc...)
The thing is - we want to export x, y & z co-ordinates for all these points - how can we do this quickly?
- and then update the information if some of them change position?
Thanks in advance
A trick I use is to export a curve to iges.
You can then create a datum-curve from file and select this iges.
On redefine of this curve Pro/E will write a feat_xxx.ibl file to your working directory.
The ibl file will have x,y,z data.
http://lti.dem.ist.utl.pt/faq/pro18/howto/dtr810/dtr810.htm
http://www.pro-classifieds.com/portal/forum/msgDetail.asp?msg_id=2513&for_id=15
Haven't tried this with points but may work. Do you have a curve thru these points ??
Here's a method I've had success with:
1. Export an IGES file of your assembly (single file) (and check the points box!)
2. Open the IGES file in a text editor
3. look for lines starting with 116
4. Copy these lines into Excel and clean them up
Here is a sample line:
116,1D1,2D2,3D3,0; 249P 125
in the above example:
166 is the IGES entity type for a point
X = 1E1 =10
Y = 2E2 = 200
Z = 3E3 = 3000
I think I have a batch file around here somewhere for parsing out points from an iges file... If I can find it, I'll upload it here.
-Brian Adkins
Couldn't find that file, but I wrote a similar one:
(We need this functionality here every so often)
This batch file will read in an iges file and then spit out the datum point x,y, & z values in two different formats... CSV and IBL (which can be read directly back into Pro/E)
-Brian Adkins
Oooops!
Don't use the batch file above.. it has a small error in it that can yield extra points in the output files...
Try this one instead.
-Brian Adkins
Thanks for the help again, Brian...
We were able to get the point data manually - will try your batch file in future,
Ed
Brian_Adkins said:
Looks like attached file was
somehow lost... here it is again:
2005-02-23_172830_iges_points.zip
Just found this - was looking for something similar. I
took the liberty of riffing on your script. I added the
capability of exporting Pro/E .pts files. The trick is,
I wanted to retain the *names* of the point features
(which are in fact preserved in the IGES file). Improved
script uploaded!
2012-02-02_192854_extract_iges_points.zip
Edited by: designviz
