Exporting Geometrical Set Name of Isolated Point to Excel 2
rhooshchow
New member
SG
Hi, I have a code that exports the name and coordinate of all points and its the geometrical set and part name along with it. However, the name of the geometrical does not appear correctly if the point is isolated, and i cant figure out how to solve for this.
Example of tree diagram:
TEST.CATPart
---GeoSet2
------Point 1
Data in Excel that i got:
Point 1 | x-coord | y-coord |z-coord | Parameters | Test
Data in Excel that i need:
Point 1 | x-coord | y-coord |z-coord | GeoSet2 | Test
Here is the code i have so far:
Sub CATMain()
On Error Resume Next
Dim hybBodies As HybridBodies
Dim hybBody As HybridBody
Dim hybShapes As HybridShapes
Dim hybShape As HybridShape
Dim arrXYZ(2)
Dim s As Long
If Err.Number <> 0 Then
MsgBox "No Active Document", vbCritical
Exit Sub
End If
'Start Excel
Err.Clear
Set objGEXCELapp = GetObject(, "EXCEL.Application")
Err.Clear
Set objGEXCELapp = CreateObject("EXCEL.Application")
End If
objGEXCELapp.Application.Visible = True
Set objGEXCELwkBks = objGEXCELapp.Application.WorkBooks
Set objGEXCELwkBk = objGEXCELwkBks.Add
Set objGEXCELwkShs = objGEXCELwkBk.Worksheets(1)
Set objGEXCELSh = objGEXCELwkBk.Sheets(1)
objGEXCELSh.cells(1, "A") = "Name"
objGEXCELSh.cells(1, "B") = "X"
objGEXCELSh.cells(1, "C") = "Y"
objGEXCELSh.cells(1, "D") = "Z"
objGEXCELSh.cells(1, "E") = "Geometrical Set"
objGEXCELSh.cells(1, "F") = "Part"
'Export to Excel
Set partDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = partDocument1.Selection
selection1.Search "CATPrtSearch.Point,sel"
For s = 1 To selection1.Count
Set hybShape = selection1.Item(s).Value
hybShape.GetCoordinates arrXYZ
objGEXCELSh.cells(s + 1, "A") = hybShape.name
objGEXCELSh.cells(s + 1, "B") = arrXYZ(0)
objGEXCELSh.cells(s + 1, "C") = arrXYZ(1)
objGEXCELSh.cells(s + 1, "D") = arrXYZ(2)
objGEXCELSh.cells(s + 1, "E") = hybShape.Parent.name
objGEXCELSh.cells(s + 1, "F") = hybShape.Parent.Parent.name
Next s
objGEXCELSh.columns("A").autofit
objGEXCELSh.columns("B").autofit
objGEXCELSh.columns("C").autofit
objGEXCELSh.columns("D").autofit
objGEXCELSh.columns("E").autofit
objGEXCELSh.columns("F").autofit
AppActivate ("Microsoft Excel")
End Sub
Any help you can provide is very much appreciated!!
Hi.
Try:
set hybShapes = hybShape.Parent
set hybBody = hybShapes.Parent
objGEXCEL..."E") = hybBody.Name
if a point is isolated, it is part of the parameters collection.
What you can do is set "define in work object" on the point-- that will set the geometrical set containing the point as the active hybridbody.
then you can get that geo set's name...
regards,
LWolf
Much thanks guys,
I combined both Little Cthullu and LWolf suggestions and got what i wanted, i will leave the code below.
Cheers
Option Explicit
Sub CATMain()
Dim ObjEXCELapp As Object
Dim ObjEXCELwkBks As Object
Dim ObjEXCELwkBk As Object
Dim ObjEXCELwkShs As Object
Dim ObjEXCELSh As Object
Dim FileSys As Object
Dim FilePath As String
Dim FileObj As File
Dim FoldObj As Folder
Dim Files1 As Files
Dim OpenDoc As Document
Dim i, g, s, o As Long
Dim ArrXYZ(2) As Variant
Set ObjEXCELapp = CreateObject("EXCEL.Application")
Set ObjEXCELwkBks = ObjEXCELapp.Application.WorkBooks
Set ObjEXCELwkBk = ObjEXCELwkBks.Add
Set ObjEXCELwkShs = ObjEXCELwkBk.Worksheets(1)
Set ObjEXCELSh = ObjEXCELwkBk.Sheets(1)
ObjEXCELSh.cells(1, "A") = "Number"
ObjEXCELSh.cells(1, "B") = "Point Name"
ObjEXCELSh.cells(1, "C") = "X"
ObjEXCELSh.cells(1, "D") = "Y"
ObjEXCELSh.cells(1, "E") = "Z"
ObjEXCELSh.cells(1, "F") = "Geometrical Set"
ObjEXCELSh.cells(1, "G") = "Part"
Set FileSys = CATIA.FileSystem
FilePath = CATIA.FileSelectionBox("Select a Catalog Part File.", "*.CATPart", CatFileSelectionModeOpen)
Set FileObj = FileSys.GetFile(FilePath)
Set FoldObj = FileObj.ParentFolder
Set Files1 = FoldObj.Files
o = 1
For i = 1 To Files1.Count
Set OpenDoc = CATIA.Documents.Open(Files1.Item(i).Path)
Dim PartDocument1 As Document
Set PartDocument1 = CATIA.ActiveDocument
Dim Part1 As Part
Set Part1 = PartDocument1.Part
Dim HybBodies1 As HybridBodies
Set HybBodies1 = Part1.HybridBodies
Dim Selection1 As Selection
Set Selection1 = PartDocument1.Selection
Dim HybBody1 As HybridBody
Dim HybShape1 As HybridShape
For g = 1 To HybBodies1.Count
Set HybBody1 = HybBodies1.Item(g)
Part1.InWorkObject = HybBody1
Selection1.Clear
Selection1.Add HybBody1
Selection1.Search "CATPrtSearch.Point,sel"
For s = 1 To Selection1.Count
Set HybShape1 = Selection1.Item(s).Value
HybShape1.GetCoordinates ArrXYZ
ObjEXCELSh.cells(o + 1, "A") = o
ObjEXCELSh.cells(o + 1, "B") = HybShape1.Name
ObjEXCELSh.cells(o + 1, "C") = ArrXYZ(0)
ObjEXCELSh.cells(o + 1, "D") = ArrXYZ(1)
ObjEXCELSh.cells(o + 1, "E") = ArrXYZ(2)
ObjEXCELSh.cells(o + 1, "F") = HybBody1.Name
ObjEXCELSh.cells(o + 1, "G") = HybShape1.Parent.Parent.Name
o = o + 1
Next s
Next g
CATIA.ActiveDocument.Close
Next i
ObjEXCELSh.columns("A").autofit
ObjEXCELSh.columns("B").autofit
ObjEXCELSh.columns("C").autofit
ObjEXCELSh.columns("D").autofit
ObjEXCELSh.columns("E").autofit
ObjEXCELSh.columns("F").autofit
ObjEXCELSh.columns("G").autofit
ObjEXCELapp.Application.Visible = True
End Sub
