Exporting design simulation results to parasolid
Fnsman810
Automotive
Aug 27, 2013
We are running an FEA analysis on some of our sub-parts in Design simulation, and I wanted to see if there was a way to export the resultant, deformed part into a parasolid. We can then add the deformed part to the assembly to check for inferences.
I checked the export function, but the parasolid option was grayed out.
Thanks.
I do not think you can export a parasolid of the results as it is a polygon body meshed data only.(Experts please do correct me if i am wrong).
But for visual checking you can surely export a JT of the results. I hope this helps in your case.
Thanks and Best Regards
Kapil Sharma
