I was asked to do a task at work involving exporting a single jt file. I was instructed, and followed up by internet, that by choosing "As a Single File" under the JT preferences before exporting, would give me one JT file. Instead I seem to get the same result as if I had never changed the setting even though I am making sure to save the configuration and go back into it to make sure it has stayed on my saved configuration. I get the file that I want but also a folder containing all the parts within the assembly. If the folder and contents are deleted or moved away from the single file, the components will not open in the JT2Go. Any tips or suggestions?
